跳转到主内容
加入维修社区 - 创建账户
eMachine T5234 RAM Disks Replacement
你所需要的
    1. eMachine T5234 RAM Disks Replacement, Shut Down Computer: 步骤 1 中的图像 1,2 eMachine T5234 RAM Disks Replacement, Shut Down Computer: 步骤 1 中的图像 2,2
      在这个步骤中使用的工具:
      Anti-Static Wrist Strap
      $7.95
      • Shut down the computer.
      • Disconnect all cables from the computer.
      • Static electricity can damage the hardware on your motherboard. Use the iFixit Anti-Static Wrist Strap or discharge the electricity by touching the metal of the case frame before unpacking the RAM disks.
      • Note: Do not remove the RAM disks from their casing until Step 8.
      询问修复机器人
      添加评论
    2. eMachine T5234 RAM Disks Replacement, Removing the Case: 步骤 2 中的图像 1,3 eMachine T5234 RAM Disks Replacement, Removing the Case: 步骤 2 中的图像 2,3 eMachine T5234 RAM Disks Replacement, Removing the Case: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      Phillips #1 Screwdriver
      $5.49
      • Place the computer upright at standing position.
      • Using a Phillips #1 Screwdriver:
      • Remove the two 1cm combination screws located on the right of the casing.
      询问修复机器人
      添加评论
    3. eMachine T5234 RAM Disks Replacement: 步骤 3 中的图像 1,2 eMachine T5234 RAM Disks Replacement: 步骤 3 中的图像 2,2
      • Using your hands, dislodge the casing and pull the case panel towards you until the panel comes off.
      询问修复机器人
      添加评论
    4. eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: 步骤 4 中的图像 1,3 eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: 步骤 4 中的图像 2,3 eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: 步骤 4 中的图像 3,3
      • With the case panel open, locate the two RAM disk slots on the right side of the motherboard.
      • Do not touch the motherboard with your hands. The oil on your skin can damage or destroy the hardware modules.
      询问修复机器人
      添加评论
    5. eMachine T5234 RAM Disks Replacement, Remove the RAM Disks: 步骤 5 中的图像 1,2 eMachine T5234 RAM Disks Replacement, Remove the RAM Disks: 步骤 5 中的图像 2,2
      • Locate the tabs on the RAM disks.
      • Use your index finger to release the tab at the bottom of the left RAM disk slot.
      询问修复机器人
      添加评论
    6. eMachine T5234 RAM Disks Replacement: 步骤 6 中的图像 1,3 eMachine T5234 RAM Disks Replacement: 步骤 6 中的图像 2,3 eMachine T5234 RAM Disks Replacement: 步骤 6 中的图像 3,3
      • Release the tab at the top of the left RAM disk.
      • Note: The RAM disk will pop off the motherboard when you release the bottom tab. Use the edges of the RAM disk to pick up and store the memory disk.
      • If the RAM disk does not pop off, use the edges of the disk to pull it off.
      • Store the unused RAM disk in a plastic container for future use or go to a recycling center for proper disposal.
      询问修复机器人
      添加评论
    7. eMachine T5234 RAM Disks Replacement: 步骤 7 中的图像 1,3 eMachine T5234 RAM Disks Replacement: 步骤 7 中的图像 2,3 eMachine T5234 RAM Disks Replacement: 步骤 7 中的图像 3,3
      • Release the top tab and the bottom tab to dislodge the right RAM disk.
      询问修复机器人
      添加评论
    8. eMachine T5234 RAM Disks Replacement, Installing the RAM Disks: 步骤 8 中的图像 1,1
      • Remove your new RAM disks from their casing.
      • Hold the RAM disk along the sides and avoid skin contact with any of the gold components.
      询问修复机器人
      添加评论
    9. eMachine T5234 RAM Disks Replacement: 步骤 9 中的图像 1,2 eMachine T5234 RAM Disks Replacement: 步骤 9 中的图像 2,2
      • Align the RAM disk to match the slot and insert the disk to the right memory disk slot.
      • Gently push the disk in to secure.
      • Secure the tabs at the top and bottom of the memory disk slots to lock into place.
      询问修复机器人
      添加评论
    10. eMachine T5234 RAM Disks Replacement: 步骤 10 中的图像 1,1
      • Now it's time for the second disk. Retrieve the second RAM disk from it's casing.
      询问修复机器人
      添加评论
    11. eMachine T5234 RAM Disks Replacement: 步骤 11 中的图像 1,2 eMachine T5234 RAM Disks Replacement: 步骤 11 中的图像 2,2
      • Align the RAM disk to match the slot and Insert the RAM disk to the right memory disk slot
      • Secure the tabs at the top and bottom of the RAM disk to lock into place.
      询问修复机器人
      添加评论
    12. eMachine T5234 RAM Disks Replacement, Reassembly: 步骤 12 中的图像 1,3 eMachine T5234 RAM Disks Replacement, Reassembly: 步骤 12 中的图像 2,3 eMachine T5234 RAM Disks Replacement, Reassembly: 步骤 12 中的图像 3,3
      • Use both hands to align the case panel to the case frame.
      • Once in place, push the case panel forward until it secures in place.
      询问修复机器人
      添加评论
    13. eMachine T5234 RAM Disks Replacement: 步骤 13 中的图像 1,3 eMachine T5234 RAM Disks Replacement: 步骤 13 中的图像 2,3 eMachine T5234 RAM Disks Replacement: 步骤 13 中的图像 3,3
      在这个步骤中使用的工具:
      $5.49
      • Using your Phillips #1 Screwdriver:
      • Screw the two 1cm combination screws back into place on the right side of the case panel.
      询问修复机器人
      添加评论
结论
And that’s all there is to it! Make sure to dispose your old RAM disks properly at your local recycling center.
取消:我没有完成这个指南。
Luis Lopez
于08/22/19注册
419 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 86
总计 530
