跳转到主内容
加入维修社区 - 创建账户
bObi Pet Screen Replacement
你所需要的
    1. bObi Pet Screen  Replacement, Turn bObi Pet Off: 步骤 1 中的图像 1,3 bObi Pet Screen  Replacement, Turn bObi Pet Off: 步骤 1 中的图像 2,3 bObi Pet Screen  Replacement, Turn bObi Pet Off: 步骤 1 中的图像 3,3
      • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
      • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
      询问修复机器人
      添加评论
    2. bObi Pet Screen  Replacement, Remove the Front Wheel: 步骤 2 中的图像 1,2 bObi Pet Screen  Replacement, Remove the Front Wheel: 步骤 2 中的图像 2,2
      • Grip the front wheel and pull straight up, using the screwdriver for leverage.
      • The wheel will pop out and you will see two screws beneath it.
      • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
      • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
      询问修复机器人
      添加评论
    3. bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 步骤 3 中的图像 1,3 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 步骤 3 中的图像 2,3 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 步骤 3 中的图像 3,3
      • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
      • Grip the brush compartment and pull down to reveal two screws on a red fastener.
      • Remove them with the screwdriver.
      询问修复机器人
      添加评论
    4. bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 步骤 4 中的图像 1,3 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 步骤 4 中的图像 2,3 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 步骤 4 中的图像 3,3
      • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
      • Remove the 4 screws located beneath the brush compartment.
      询问修复机器人
      添加评论
    5. bObi Pet Screen  Replacement, Remove the Cover Screws: 步骤 5 中的图像 1,2 bObi Pet Screen  Replacement, Remove the Cover Screws: 步骤 5 中的图像 2,2
      • Remove the 2 screws on the dustbin’s red fastener.
      • Remove the fastener and set it aside for reassembly.
      • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
      询问修复机器人
      添加评论
    6. bObi Pet Screen  Replacement, Detach the Cover: 步骤 6 中的图像 1,3 bObi Pet Screen  Replacement, Detach the Cover: 步骤 6 中的图像 2,3 bObi Pet Screen  Replacement, Detach the Cover: 步骤 6 中的图像 3,3
      • Lift the cover to reveal the main board underneath.
      • Remove the two circuit plugs connecting the lid to the mainboard.
      • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
      询问修复机器人
      添加评论
    1. bObi Pet Screen  Replacement, Remove the Screen: 步骤 7 中的图像 1,3 bObi Pet Screen  Replacement, Remove the Screen: 步骤 7 中的图像 2,3 bObi Pet Screen  Replacement, Remove the Screen: 步骤 7 中的图像 3,3
      • Remove the four screws holding bObi Pet's screen.
      • Then, lift it straight up and out to make space for the replacement.
      询问修复机器人
      添加评论
    2. bObi Pet Screen  Replacement, Place the New Screen: 步骤 8 中的图像 1,3 bObi Pet Screen  Replacement, Place the New Screen: 步骤 8 中的图像 2,3 bObi Pet Screen  Replacement, Place the New Screen: 步骤 8 中的图像 3,3
      • Lay the new screen in the open space on bObi Pet's lid.
      • Align the screw holes on the screen with the screw posts in bObi Pet and push down until it lies flat.
      • Install all four screws, and you'll be ready to close bObi Pet. See the following instructions: Assemble bObi Pet Post-Repair
      询问修复机器人
      添加评论
结论
To reassemble bObi Pet, see this tutorial: Assemble bObi Pet Post-Repair
取消:我没有完成这个指南。
Chelsea
于09/24/14注册
2,278 声望
创作了31篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 300
