跳转到主内容
加入维修社区 - 创建账户
Zune Flash 2nd Generation Face Plate Replacement
你所需要的
    1. Zune Flash 2nd Generation Face Plate Replacement, Back Cover: 步骤 1 中的图像 1,2 Zune Flash 2nd Generation Face Plate Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
      • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
      • PICS MAKE NO SENSE.
      添加评论
    2. Zune Flash 2nd Generation Face Plate Replacement: 步骤 2 中的图像 1,2 Zune Flash 2nd Generation Face Plate Replacement: 步骤 2 中的图像 2,2
      • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
      • You should hear a 'click' as the clip detaches from the device.
      询问修复机器人
      添加评论
    3. Zune Flash 2nd Generation Face Plate Replacement: 步骤 3 中的图像 1,1
      • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
      询问修复机器人
      添加评论
    4. Zune Flash 2nd Generation Face Plate Replacement: 步骤 4 中的图像 1,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 4 中的图像 2,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 4 中的图像 3,3
      • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
      询问修复机器人
      添加评论
    5. Zune Flash 2nd Generation Face Plate Replacement: 步骤 5 中的图像 1,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 5 中的图像 2,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 5 中的图像 3,3
      • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
      询问修复机器人
      添加评论
    1. Zune Flash 2nd Generation Face Plate Replacement, Face Plate: 步骤 6 中的图像 1,2 Zune Flash 2nd Generation Face Plate Replacement, Face Plate: 步骤 6 中的图像 2,2
      • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
      • Be sure to put this set of screws aside since they are a different size than any other screws in the device.
      询问修复机器人
      添加评论
    2. Zune Flash 2nd Generation Face Plate Replacement: 步骤 7 中的图像 1,2 Zune Flash 2nd Generation Face Plate Replacement: 步骤 7 中的图像 2,2
      • Use your finger or a Zune opening tool to pry back the two clear flaps.
      • Next lift the communications board that was being held down by the clear flaps.
      • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
      询问修复机器人
      添加评论
    3. Zune Flash 2nd Generation Face Plate Replacement: 步骤 8 中的图像 1,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 8 中的图像 2,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 8 中的图像 3,3
      • Disconnect the ribbon with the plastic opening tool by flipping up the black plastic flap where the ribbon connects to the memory board.
      • Carefully pull the ribbon out of the memory board, ensuring that the black plastic flap is up before removal to avoid the ripping the ribbon.
      询问修复机器人
      添加评论
    4. Zune Flash 2nd Generation Face Plate Replacement: 步骤 9 中的图像 1,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 9 中的图像 2,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 9 中的图像 3,3
      • Remove the battery by prying the battery off from the bottom with a Zune opening tool.
      • There is an adhesive between the battery and the device, therefore use a metal spudger to finish detaching the battery.
      • Be sure not to puncture the battery in any way when using the metal spudger.
      询问修复机器人
      添加评论
    5. Zune Flash 2nd Generation Face Plate Replacement: 步骤 10 中的图像 1,2 Zune Flash 2nd Generation Face Plate Replacement: 步骤 10 中的图像 2,2
      • Remove the single screw under the battery using a small Tri-Wing screwdriver.
      询问修复机器人
      添加评论
    6. Zune Flash 2nd Generation Face Plate Replacement: 步骤 11 中的图像 1,1
      • Disconnect the faceplate from the device by depressing the two tabs located near the middle of each of the sides using a metal spudger.
      • This will disconnect the last circuit board in the device from the center frame.
      询问修复机器人
      添加评论
    7. Zune Flash 2nd Generation Face Plate Replacement: 步骤 12 中的图像 1,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 12 中的图像 2,3 Zune Flash 2nd Generation Face Plate Replacement: 步骤 12 中的图像 3,3
      • Remove the faceplate by using a metal spudger to separate it from the remaining components.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
ybahman
于11/01/09注册
139 声望
创作了4篇指南
团队
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 的会员
CPSU-REGAN-F09S9G20
5 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 35
过去 30 天: 62
总计 4,310
