跳转到主内容
加入维修社区 - 创建账户
Zoomer Dino Boomer Back Button Replacement
你所需要的
    1. Zoomer Dino Boomer Back Button Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Power off Zoomer Dino Boomer before disassembly.
      • Remove the eight 9.3mm Phillips #1 screws.
      询问修复机器人
      添加评论
    2. Zoomer Dino Boomer Back Button Replacement: 步骤 2 中的图像 1,2 Zoomer Dino Boomer Back Button Replacement: 步骤 2 中的图像 2,2
      • Turn dinosaur over and hold upright.
      • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
      • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
      询问修复机器人
      添加评论
    3. Zoomer Dino Boomer Back Button Replacement: 步骤 3 中的图像 1,3 Zoomer Dino Boomer Back Button Replacement: 步骤 3 中的图像 2,3 Zoomer Dino Boomer Back Button Replacement: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
      • Remove back cover.
      • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
      • Do not damage the wires or circuit board.
      询问修复机器人
      添加评论
    1. Zoomer Dino Boomer Back Button Replacement, Back Button: 步骤 4 中的图像 1,1
      • Where the button is largest, squeeze the two white tabs together.
      询问修复机器人
      添加评论
    2. Zoomer Dino Boomer Back Button Replacement: 步骤 5 中的图像 1,1
      • Push in the white circular piece between these tabs as far as it will go.
      询问修复机器人
      添加评论
    3. Zoomer Dino Boomer Back Button Replacement: 步骤 6 中的图像 1,2 Zoomer Dino Boomer Back Button Replacement: 步骤 6 中的图像 2,2
      • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
      • Remove the back button.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 46
总计 2,563
