跳转到主内容
加入维修社区 - 创建账户
Zebra ZP 450 Feed Key Replacement
你所需要的
    1. Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 步骤 1 中的图像 1,2 Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 步骤 1 中的图像 2,2
      • This device uses electricity, so it is best to unplug it before going any farther.
      • Remove 5 11.08mm Phillips screws that will come out of the casing once loose.
      • There is one Phillips screw at the bottom center set deep inside the casing - it is easy to get to with a thin screwdriver. This screw will come loose, but stay inside the casing. Don't be surprised when it won't drop out.
      询问修复机器人
      添加评论
    2. Zebra ZP 450 Feed Key Replacement, Remove Top: 步骤 2 中的图像 1,1
      • Position your hands one on either side of the top.
      • Put your thumbs on the front and your 4 fingers on the sides.
      • Push outwards with your 4 fingers to remove the plastic top.
      • Wiggling the top may help loosen it from the bottom screw that is still in the case.
      询问修复机器人
      添加评论
    3. Zebra ZP 450 Feed Key Replacement, Open Lid: 步骤 3 中的图像 1,2 Zebra ZP 450 Feed Key Replacement, Open Lid: 步骤 3 中的图像 2,2
      • Put the lid back down and lay the top open as shown in the photo.
      • Be careful setting the lid down, as it could pull wiring from other components. If you need more wiggle room, you can remove the silver cable from the support clip on the side, as seen in the second photo by pulling the tab back and pushing the cable up.
      • The component we are replacing is on the underneath of the top of the device, highlighted in the photo
      询问修复机器人
      添加评论
    4. Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 步骤 4 中的图像 1,2 Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 步骤 4 中的图像 2,2
      • Starting with either ribbon cable, grip it on either side and gently pull out - The cable will come out of it's connector.
      • Repeat for other ribbon cable
      • Ribbons may be fragile, so handle with care.
      询问修复机器人
      添加评论
    5. Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 步骤 5 中的图像 1,3 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 步骤 5 中的图像 2,3 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 步骤 5 中的图像 3,3
      • Remove 2 7.51mm Phillips screws holding the circuit board onto the device casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 1-28, Donnelly Fall 2014 USF Tampa, Team 1-28, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G28
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 2,173
