跳转到主内容
ZTE Tempo Headphone Jack Replacement
你所需要的
  1. ZTE Tempo Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,2 ZTE Tempo Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Headphone Jack Replacement: 步骤 2 中的图像 1,3 ZTE Tempo Headphone Jack Replacement: 步骤 2 中的图像 2,3 ZTE Tempo Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Unplug wires by pushing up with the plastic opening tool
  3. ZTE Tempo Headphone Jack Replacement: 步骤 3 中的图像 1,2 ZTE Tempo Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Push up with the plastic opening tool to remove the motherboard.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
  4. ZTE Tempo Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
  5. ZTE Tempo Headphone Jack Replacement: 步骤 5 中的图像 1,2 ZTE Tempo Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Desolder and remove in front of the motherboard.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 208
