跳转到主内容
ZTE Max XL SIM Card Replacement
你所需要的
  1. ZTE Max XL SIM Card Replacement, Battery: 步骤 1 中的图像 1,2 ZTE Max XL SIM Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. ZTE Max XL SIM Card Replacement: 步骤 2 中的图像 1,2 ZTE Max XL SIM Card Replacement: 步骤 2 中的图像 2,2
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On the phone shown there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL SIM Card Replacement: 步骤 3 中的图像 1,3 ZTE Max XL SIM Card Replacement: 步骤 3 中的图像 2,3 ZTE Max XL SIM Card Replacement: 步骤 3 中的图像 3,3
    • Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side.
    • Use extreme caution to not puncture the lithium ion battery.
  4. ZTE Max XL SIM Card Replacement: 步骤 4 中的图像 1,2 ZTE Max XL SIM Card Replacement: 步骤 4 中的图像 2,2
    • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
    • There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
  5. ZTE Max XL SIM Card Replacement: 步骤 5 中的图像 1,2 ZTE Max XL SIM Card Replacement: 步骤 5 中的图像 2,2
    • After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
  6. ZTE Max XL SIM Card Replacement: 步骤 6 中的图像 1,3 ZTE Max XL SIM Card Replacement: 步骤 6 中的图像 2,3 ZTE Max XL SIM Card Replacement: 步骤 6 中的图像 3,3
    • Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
  7. ZTE Max XL SIM Card Replacement: 步骤 7 中的图像 1,3 ZTE Max XL SIM Card Replacement: 步骤 7 中的图像 2,3 ZTE Max XL SIM Card Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening pick between the screen and side trim battery cover to remove the screen.
    • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
  8. ZTE Max XL SIM Card Replacement: 步骤 8 中的图像 1,1
    • On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
  9. ZTE Max XL SIM Card Replacement: 步骤 9 中的图像 1,1
    • Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
    • Use extreme caution to not overheat the battery. Never use any open flames or high heat.
    • Adhesive is used to secure the battery to the phone. If you're having problems you may need to heat the screen as well.
  10. ZTE Max XL SIM Card Replacement: 步骤 10 中的图像 1,3 ZTE Max XL SIM Card Replacement: 步骤 10 中的图像 2,3 ZTE Max XL SIM Card Replacement: 步骤 10 中的图像 3,3
    • Using the iFixit opening tools carefully pry the edges of the battery away from the casing.
    • While prying, take care to not scrape the wires underneath the battery.
  11. ZTE Max XL SIM Card Replacement: 步骤 11 中的图像 1,1
    • With the battery removed, you can now insert the new battery or replace other parts within your phone.
  12. ZTE Max XL SIM Card Replacement, SIM Card: 步骤 12 中的图像 1,3 ZTE Max XL SIM Card Replacement, SIM Card: 步骤 12 中的图像 2,3 ZTE Max XL SIM Card Replacement, SIM Card: 步骤 12 中的图像 3,3
    • Disconnect the six connections located on the large circuit board.
    • The camera itself is lightweight so take care during disconnection of the connector not to lose it.
  13. ZTE Max XL SIM Card Replacement: 步骤 13 中的图像 1,2 ZTE Max XL SIM Card Replacement: 步骤 13 中的图像 2,2
    • Gently pry off the large circuit board using the plastic spudger.
  14. ZTE Max XL SIM Card Replacement: 步骤 14 中的图像 1,1
    • With the circuit board removed, press the small button next to the SIM Card slot, this will cause the tray to pop out slightly. Remove the SIM card tray.
结论
4等其他人完成本指南。
Olivia Wolf
于02/15/18注册
1,400 声望
创作了5篇指南
团队
UW Stout, Team S8-G2, Ogden Spring 2018 UW Stout, Team S8-G2, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G2
4 名成员
创作了10篇指南
2条评论
My husband cell phone is a zte android and the plug in part was complelty not workimg so he took the back off and all that changed the usb plug in charger part and put his cell back together and it charges and it works besides when je gets on line like google it lets him on for just a swcond and then jt will say lost connection check your netwprk and we have unlimited high speed data is there something he might of accidently done wrong when he replaced the charging part please help
sissybyford - 回复
why is it so difficult to change a SIM CARD?!!
[deleted] - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 2,627
