跳转到主内容
加入维修社区 - 创建账户
ZTE Maven 3 Screen Replacement
你所需要的
    1. ZTE Maven 3 Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 ZTE Maven 3 Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 ZTE Maven 3 Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
      询问修复机器人
      添加评论
    1. ZTE Maven 3 Screen Replacement, Battery: 步骤 2 中的图像 1,3 ZTE Maven 3 Screen Replacement, Battery: 步骤 2 中的图像 2,3 ZTE Maven 3 Screen Replacement, Battery: 步骤 2 中的图像 3,3
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
      询问修复机器人
      添加评论
    1. ZTE Maven 3 Screen Replacement, Midframe: 步骤 3 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
      询问修复机器人
      添加评论
    2. ZTE Maven 3 Screen Replacement: 步骤 4 中的图像 1,1
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
      询问修复机器人
      添加评论
    3. ZTE Maven 3 Screen Replacement: 步骤 5 中的图像 1,2 ZTE Maven 3 Screen Replacement: 步骤 5 中的图像 2,2
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
      询问修复机器人
      添加评论
    1. ZTE Maven 3 Screen Replacement, Motherboard: 步骤 6 中的图像 1,1
      • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
      询问修复机器人
      添加评论
    2. ZTE Maven 3 Screen Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Please locate the black wire that’s attached to gold plates on the left side of the device.
      • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
      询问修复机器人
      添加评论
    3. ZTE Maven 3 Screen Replacement: 步骤 8 中的图像 1,2 ZTE Maven 3 Screen Replacement: 步骤 8 中的图像 2,2
      • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
      • 2 adhesive ribbon cables (green circles).
      • One ribbon cable that slides out (orange circles).
      • Three ribbon cables that pop in and out (yellow circles).
      询问修复机器人
      添加评论
    4. ZTE Maven 3 Screen Replacement: 步骤 9 中的图像 1,3 ZTE Maven 3 Screen Replacement: 步骤 9 中的图像 2,3 ZTE Maven 3 Screen Replacement: 步骤 9 中的图像 3,3
      • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
      询问修复机器人
      添加评论
    5. ZTE Maven 3 Screen Replacement: 步骤 10 中的图像 1,2 ZTE Maven 3 Screen Replacement: 步骤 10 中的图像 2,2
      • Grab the opening pick and work it into the edges of the motherboard.
      • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
      • Remove the motherboard and put it aside.
      询问修复机器人
      添加评论
    1. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 步骤 11 中的图像 1,2 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 步骤 11 中的图像 2,2
      • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
      询问修复机器人
      添加评论
    1. ZTE Maven 3 Screen Replacement, Screen: 步骤 12 中的图像 1,1
      • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 的会员
UMASSD-KONN-F23S3G1
3 名成员
创作了70篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 349
