跳转到主内容
加入维修社区 - 创建账户
ZTE Compel Motherboard Replacement
你所需要的
  1. ZTE Compel Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
    询问修复机器人
    添加评论
  2. ZTE Compel Motherboard Replacement: 步骤 2 中的图像 1,1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
    询问修复机器人
    添加评论
  3. ZTE Compel Motherboard Replacement: 步骤 3 中的图像 1,1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
    询问修复机器人
    添加评论
  4. ZTE Compel Motherboard Replacement, Camera: 步骤 4 中的图像 1,2 ZTE Compel Motherboard Replacement, Camera: 步骤 4 中的图像 2,2
    • Remove the 9 screws that measure 4 mm Phillips #000.
    • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
    询问修复机器人
    添加评论
  5. ZTE Compel Motherboard Replacement: 步骤 5 中的图像 1,3 ZTE Compel Motherboard Replacement: 步骤 5 中的图像 2,3 ZTE Compel Motherboard Replacement: 步骤 5 中的图像 3,3
    • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
    询问修复机器人
    添加评论
  6. ZTE Compel Motherboard Replacement: 步骤 6 中的图像 1,2 ZTE Compel Motherboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
    • Grip the camera with your tweezers and lift up to remove the camera.
    • May need to use light force to remove camera due to the adhesive on the motherboard.
    询问修复机器人
    添加评论
  7. ZTE Compel Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 ZTE Compel Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your tweezers to remove the black electrical tape covering connectors to the motherboard.
    • Use your tweezers to flip the brown clip up, and pull the ribbon connectors out of the connections.
    询问修复机器人
    添加评论
  8. ZTE Compel Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use your tweezers to disconnect the final ribbon connector underneath the motherboard at the top of the phone. The motherboard can now be separated from the LCD Screen.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Ohio State, Team S1-G4, Whitney Fall 2018 Ohio State, Team S1-G4, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G4
2 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 24
总计 591
