跳转到主内容
加入维修社区 - 创建账户
ZCWA BR151 Wheel Replacement
你所需要的
    1. ZCWA BR151 Wheel Replacement, Water Tank: 步骤 1 中的图像 1,1
      • Turn off the device.
      询问修复机器人
      添加评论
    2. ZCWA BR151 Wheel Replacement: 步骤 2 中的图像 1,2 ZCWA BR151 Wheel Replacement: 步骤 2 中的图像 2,2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      询问修复机器人
      添加评论
    1. ZCWA BR151 Wheel Replacement, Wheel: 步骤 3 中的图像 1,2 ZCWA BR151 Wheel Replacement, Wheel: 步骤 3 中的图像 2,2
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      询问修复机器人
      添加评论
    2. ZCWA BR151 Wheel Replacement: 步骤 4 中的图像 1,1
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      询问修复机器人
      添加评论
    3. ZCWA BR151 Wheel Replacement: 步骤 5 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      询问修复机器人
      添加评论
    4. ZCWA BR151 Wheel Replacement: 步骤 6 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
      询问修复机器人
      添加评论
    5. ZCWA BR151 Wheel Replacement: 步骤 7 中的图像 1,2 ZCWA BR151 Wheel Replacement: 步骤 7 中的图像 2,2
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      询问修复机器人
      添加评论
    6. ZCWA BR151 Wheel Replacement: 步骤 8 中的图像 1,1
      • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      询问修复机器人
      添加评论
    7. ZCWA BR151 Wheel Replacement: 步骤 9 中的图像 1,3 ZCWA BR151 Wheel Replacement: 步骤 9 中的图像 2,3 ZCWA BR151 Wheel Replacement: 步骤 9 中的图像 3,3
      • Using a Phillips #1 screwdriver, remove the single screw to the spring.
      • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
      询问修复机器人
      添加评论
    8. ZCWA BR151 Wheel Replacement: 步骤 10 中的图像 1,2 ZCWA BR151 Wheel Replacement: 步骤 10 中的图像 2,2
      • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
      • Pinch the silver brackets and pull the wire casing away from the motherboard.
      • Remove the wheel from the vacuum.
      • Repeat Steps 6-10 to replace the wheel on the opposite side.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 49
总计 1,116
