跳转到主内容
加入维修社区 - 创建账户
ZCWA BR151 Velcro Replacement
你所需要的
    1. ZCWA BR151 Velcro Replacement, Velcro: 步骤 1 中的图像 1,2 ZCWA BR151 Velcro Replacement, Velcro: 步骤 1 中的图像 2,2
      • Turn off the device.
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      询问修复机器人
      添加评论
    2. ZCWA BR151 Velcro Replacement: 步骤 2 中的图像 1,1
      • Use a Jimmy to get underneath the velcro until you are able to push it up enough to grab.
      询问修复机器人
      添加评论
    3. ZCWA BR151 Velcro Replacement: 步骤 3 中的图像 1,1
      • Use tweezers to peel off the rest of the velcro.
      • If necessary, use the spudger to remove more of the adhesive beneath the velcro.
      询问修复机器人
      添加评论
      • You will need four velcro strips. Cut out two, 1-inch long strips of velcro.
      • Cut an additional two, 3-inch long strips.
      询问修复机器人
      添加评论
      • If your velcro strips already have an adhesive back, simply attach them to the top of the mop bracket.
      • If you are using a hot glue gun to attach your velcro, place a small section of glue where you want the velcro to go, then carefully press your piece down.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 509
