跳转到主内容
加入维修社区 - 创建账户
Yuneec Breeze 4K Camera Replacement
你所需要的
    1. Yuneec Breeze 4K Camera Replacement, Camera: 步骤 1 中的图像 1,2 Yuneec Breeze 4K Camera Replacement, Camera: 步骤 1 中的图像 2,2
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
      询问修复机器人
      添加评论
    2. Yuneec Breeze 4K Camera Replacement: 步骤 2 中的图像 1,1
      • Using small pliers grip the connector of the wire and pull it out slowly.
      询问修复机器人
      添加评论
    3. Yuneec Breeze 4K Camera Replacement: 步骤 3 中的图像 1,1
      • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
      询问修复机器人
      添加评论
    4. Yuneec Breeze 4K Camera Replacement: 步骤 4 中的图像 1,1
      • Unplug the two vertical plugs located in the rear of the M7 board.
      询问修复机器人
      添加评论
    5. Yuneec Breeze 4K Camera Replacement: 步骤 5 中的图像 1,1
      • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
      询问修复机器人
      添加评论
    6. Yuneec Breeze 4K Camera Replacement: 步骤 6 中的图像 1,1
      • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
      询问修复机器人
      添加评论
    7. Yuneec Breeze 4K Camera Replacement: 步骤 7 中的图像 1,2 Yuneec Breeze 4K Camera Replacement: 步骤 7 中的图像 2,2
      • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
      询问修复机器人
      添加评论
    8. Yuneec Breeze 4K Camera Replacement: 步骤 8 中的图像 1,1
      • Using a pair of pliers pull apart the battery connector.
      询问修复机器人
      添加评论
    9. Yuneec Breeze 4K Camera Replacement: 步骤 9 中的图像 1,1
      • Flip over the entire frame along with the M7 board and the A9 board.
      询问修复机器人
      添加评论
    10. Yuneec Breeze 4K Camera Replacement: 步骤 10 中的图像 1,1
      • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
      询问修复机器人
      添加评论
    11. Yuneec Breeze 4K Camera Replacement: 步骤 11 中的图像 1,1
      • Unplug the only wire that is connected to the A9 board.
      询问修复机器人
      添加评论
    12. Yuneec Breeze 4K Camera Replacement: 步骤 12 中的图像 1,1
      • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
      询问修复机器人
      添加评论
    13. Yuneec Breeze 4K Camera Replacement: 步骤 13 中的图像 1,1
      • Unscrew the four screws that are holding the camera to the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Wes Knutson
于10/04/18注册
481 声望
创作了3篇指南
团队
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G5
4 名成员
创作了4篇指南
1指南评论
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 2,441
