简介
If the screen on your Luna is damaged or not functioning, it can be replaced following these steps.
你所需要的
Flip the device over so that the batteries are closest to you.
Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
Push the battery against the spring and lift it out of the casing.
Repeat with the other battery.
Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
Unscrew two 10mm silver screws at the base of the LCD screen to free it from the chassis.
