跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note Rear Camera Replacement
你所需要的
  1. Xiaomi Redmi Note Rear Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    询问修复机器人
    添加评论
  2. Xiaomi Redmi Note Rear Camera Replacement: 步骤 2 中的图像 1,2 Xiaomi Redmi Note Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    询问修复机器人
    添加评论
  3. Xiaomi Redmi Note Rear Camera Replacement: 步骤 3 中的图像 1,2 Xiaomi Redmi Note Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    询问修复机器人
    添加评论
  4. Xiaomi Redmi Note Rear Camera Replacement, Midframe: 步骤 4 中的图像 1,2 Xiaomi Redmi Note Rear Camera Replacement, Midframe: 步骤 4 中的图像 2,2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    询问修复机器人
    添加评论
  5. Xiaomi Redmi Note Rear Camera Replacement: 步骤 5 中的图像 1,2 Xiaomi Redmi Note Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    询问修复机器人
    添加评论
  6. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: 步骤 6 中的图像 1,2 Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: 步骤 6 中的图像 2,2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
AJ Beers
于04/26/17注册
213 声望
创作了2篇指南
团队
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G4
4 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 36
总计 4,284
