跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note Charging Port Replacement
你所需要的
  1. Xiaomi Redmi Note Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    询问修复机器人
    添加评论
  2. Xiaomi Redmi Note Charging Port Replacement: 步骤 2 中的图像 1,2 Xiaomi Redmi Note Charging Port Replacement: 步骤 2 中的图像 2,2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    询问修复机器人
    添加评论
  3. Xiaomi Redmi Note Charging Port Replacement: 步骤 3 中的图像 1,2 Xiaomi Redmi Note Charging Port Replacement: 步骤 3 中的图像 2,2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    询问修复机器人
    添加评论
  4. Xiaomi Redmi Note Charging Port Replacement, Midframe: 步骤 4 中的图像 1,2 Xiaomi Redmi Note Charging Port Replacement, Midframe: 步骤 4 中的图像 2,2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    询问修复机器人
    添加评论
  5. Xiaomi Redmi Note Charging Port Replacement: 步骤 5 中的图像 1,2 Xiaomi Redmi Note Charging Port Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    询问修复机器人
    添加评论
  6. Xiaomi Redmi Note Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,2 Xiaomi Redmi Note Charging Port Replacement, Charging Port: 步骤 6 中的图像 2,2
    • Locate the charging port panel at the bottom of the device.
    • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
    询问修复机器人
    添加评论
  7. Xiaomi Redmi Note Charging Port Replacement: 步骤 7 中的图像 1,3 Xiaomi Redmi Note Charging Port Replacement: 步骤 7 中的图像 2,3 Xiaomi Redmi Note Charging Port Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the antenna cable at the top right corner of the charging port.
    • Lift the antenna cable off of the panel with tweezers.
    询问修复机器人
    添加评论
  8. Xiaomi Redmi Note Charging Port Replacement: 步骤 8 中的图像 1,3 Xiaomi Redmi Note Charging Port Replacement: 步骤 8 中的图像 2,3 Xiaomi Redmi Note Charging Port Replacement: 步骤 8 中的图像 3,3
    • Flip the panel to its back side, but do not fully lift it off of the phone yet.
    • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
    询问修复机器人
    添加评论
  9. Xiaomi Redmi Note Charging Port Replacement: 步骤 9 中的图像 1,1
    • Lift the charging port up to remove it from the frame.
    添加评论
结论
取消:我没有完成这个指南。
26等其他人完成本指南。
团队
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G4
4 名成员
创作了32篇指南
9指南评论
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - 回复 分享
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - 回复 分享
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - 回复 分享
How much is it to repair in Qatar riyal
Cynthia - 回复 分享
How much does it cost to repair the charging port in Qatar royals?
Cynthia - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 41
过去 30 天: 195
总计 43,052
