简介
In this guide, I will show you how to replace the main brush assembly.
你所需要的
Remove the main brush holder by pressing both locks inward and lifting it up.
Remove the main brush.
Remove the screw holding the side brush.
Remove the side brush along with the screw by lifting it upward.
Lift the front wheel with the screwdriver.
Completely pull the front wheel upward to remove it.
Remove the seven screws holding the bottom panel.
Lift the bottom cover up.
Remove the four screws from the main brush assembly
Lift out the main brush assembly upwards
Work through the steps in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
