简介
In this guide, I will show you how to replace the laser unit or the LIDAR or its motor.
Replacing the entire unit or just the motor can be the solution if the Roborock S5 reports "Error 1".
你所需要的
Insert the spudger from the side
Release the clips by turning the spudger
Lift the cover upwards
Loosen the 6 screws for the hinges
Lift and remove the hinges
Remove the flap upwards
Work through the steps in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
