简介
Use this guide to replace a cracked or broken screen on your Xiaomi Poco F3.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
If your battery is swollen, take appropriate precautions. Before disassembling your device, discharge the battery below 25%. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You'll need replacement adhesive in order to complete this repair.
你所需要的
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the eleven screws securing the motherboard cover:
Ten 3.4 mm-long screws
One 1.5 mm-long screw
Insert the tip of an opening pick under the bottom left edge of the motherboard cover.
Use the opening pick to lift up the motherboard cover and release the plastic clips that hold the cover in its place.
Use your fingers to lift up the motherboard cover to access the connector on the motherboard.
Use a spudger to disconnect the motherboard cover by prying the connector straight up from its socket at the motherboard.
Remove the motherboard cover.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left bottom edge of the Poco F3.
Press firmly to eject the tray.
Remove the SIM card tray from the phone.
Use a Phillips screwdriver to remove the seven 3.5 mm-long screws securing the loudspeaker.
Use a spudger to pry up and disconnect the black antenna cable from the motherboard.
Insert an opening pick between the frame and the top left of the loudspeaker.
Use the opening pick to pry up the loudspeaker by tilting it downwards.
Use the flat end of a spudger to pry up and disconnect the screen flex cable connector on the daughterboard.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the screen, as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick in the gap you just created and slide it to the bottom left corner to cut the adhesive.
Leave the pick in place to prevent the adhesive from resealing.
Thread the display flex cable through the gap in the midframe and remove the display.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
9等其他人完成本指南。
3条评论
I've opened the screen but all of a sudden when I click on the screen it doesn't work
nice perfectly thanks
Arifin Lar - 回复
