简介
Use this guide to replace the rear glass on your Xiaomi Poco F3.
You'll need replacement adhesive in order to complete this repair.
你所需要的
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
4等其他人完成本指南。
4条评论
Do I have to remove the whole back?
Can't I just remove the glass back?
Hi, yes, you have to remove the complete rear glass. Good luck with the repair!
