跳转到主内容
加入维修社区 - 创建账户
Xiaomi Mi Note Front camera Replacement
你所需要的
    1. Xiaomi Mi Note Front camera Replacement, Dual SIM SD Card: 步骤 1 中的图像 1,1
      • Locate the hole for the Dual SIM SD card on the left side of the phone.
      询问修复机器人
      添加评论
    2. Xiaomi Mi Note Front camera Replacement: 步骤 2 中的图像 1,2 Xiaomi Mi Note Front camera Replacement: 步骤 2 中的图像 2,2
      • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
      询问修复机器人
      添加评论
    1. Xiaomi Mi Note Front camera Replacement, Battery: 步骤 3 中的图像 1,2 Xiaomi Mi Note Front camera Replacement, Battery: 步骤 3 中的图像 2,2
      • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
      添加评论
    2. Xiaomi Mi Note Front camera Replacement: 步骤 4 中的图像 1,3 Xiaomi Mi Note Front camera Replacement: 步骤 4 中的图像 2,3 Xiaomi Mi Note Front camera Replacement: 步骤 4 中的图像 3,3
      • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
      • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
      • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
      • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
      添加评论
    3. Xiaomi Mi Note Front camera Replacement: 步骤 5 中的图像 1,1
      • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. Xiaomi Mi Note Front camera Replacement: 步骤 6 中的图像 1,2 Xiaomi Mi Note Front camera Replacement: 步骤 6 中的图像 2,2
      • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
      • Glue will be holding down the backside of the battery.
      添加评论
    1. Xiaomi Mi Note Front camera Replacement, Front camera: 步骤 7 中的图像 1,1
      • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
      询问修复机器人
      添加评论
    2. Xiaomi Mi Note Front camera Replacement: 步骤 8 中的图像 1,2 Xiaomi Mi Note Front camera Replacement: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
      • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
      • When detaching the ribbon on the left use minimal force to prevent damage.
      询问修复机器人
      添加评论
    3. Xiaomi Mi Note Front camera Replacement: 步骤 9 中的图像 1,2 Xiaomi Mi Note Front camera Replacement: 步骤 9 中的图像 2,2
      • Use a tweezer to lift and remove the motherboard from the frame.
      • Be sure that the Dual SIM card and tray has been removed.
      询问修复机器人
      添加评论
    4. Xiaomi Mi Note Front camera Replacement: 步骤 10 中的图像 1,1
      • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G6
4 名成员
创作了18篇指南
1指南评论
Telefonumu 2 hafta önce suya düşürdüm ilk etapta açılmadı ama şimdi açılıyor ama kamera çalışmıyor ön kamera Bir de hoparlörü boğuk çıkıyor tamir etsene
Kaan Guney - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 3,005
