跳转到主内容
Xbox Series X Power Supply Replacement
你所需要的
  1. Xbox Series X Power Supply Replacement, Uncover the back panel screws: 步骤 1 中的图像 1,2 Xbox Series X Power Supply Replacement, Uncover the back panel screws: 步骤 1 中的图像 2,2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Power Supply Replacement: 步骤 2 中的图像 1,3 Xbox Series X Power Supply Replacement: 步骤 2 中的图像 2,3 Xbox Series X Power Supply Replacement: 步骤 2 中的图像 3,3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Power Supply Replacement, Remove the back panel screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $16.96
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Power Supply Replacement, Unclip the back panel: 步骤 4 中的图像 1,3 Xbox Series X Power Supply Replacement, Unclip the back panel: 步骤 4 中的图像 2,3 Xbox Series X Power Supply Replacement, Unclip the back panel: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Power Supply Replacement: 步骤 5 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 5 中的图像 2,2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Power Supply Replacement, Remove the back panel: 步骤 6 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the back panel: 步骤 6 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the back panel: 步骤 6 中的图像 3,3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Power Supply Replacement: 步骤 7 中的图像 1,3 Xbox Series X Power Supply Replacement: 步骤 7 中的图像 2,3 Xbox Series X Power Supply Replacement: 步骤 7 中的图像 3,3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Power Supply Replacement, Remove the fan screws: 步骤 8 中的图像 1,1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Power Supply Replacement, Disconnect the fan cable: 步骤 9 中的图像 1,3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: 步骤 9 中的图像 2,3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Power Supply Replacement, Remove the fan: 步骤 10 中的图像 1,2 Xbox Series X Power Supply Replacement, Remove the fan: 步骤 10 中的图像 2,2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Power Supply Replacement, Unlatch the base: 步骤 11 中的图像 1,3 Xbox Series X Power Supply Replacement, Unlatch the base: 步骤 11 中的图像 2,3 Xbox Series X Power Supply Replacement, Unlatch the base: 步骤 11 中的图像 3,3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Power Supply Replacement, Twist and remove the base: 步骤 12 中的图像 1,3 Xbox Series X Power Supply Replacement, Twist and remove the base: 步骤 12 中的图像 2,3 Xbox Series X Power Supply Replacement, Twist and remove the base: 步骤 12 中的图像 3,3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Power Supply Replacement, Remove the optical drive screws: 步骤 13 中的图像 1,2 Xbox Series X Power Supply Replacement, Remove the optical drive screws: 步骤 13 中的图像 2,2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Power Supply Replacement, Remove the vibration isolator: 步骤 14 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: 步骤 14 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: 步骤 14 中的图像 3,3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Power Supply Replacement, Disconnect the power and data cables: 步骤 15 中的图像 1,3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: 步骤 15 中的图像 2,3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Power Supply Replacement, Remove the optical drive: 步骤 16 中的图像 1,2 Xbox Series X Power Supply Replacement, Remove the optical drive: 步骤 16 中的图像 2,2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Power Supply Replacement, Disconnect the USB port cable: 步骤 17 中的图像 1,3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: 步骤 17 中的图像 2,3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: 步骤 17 中的图像 3,3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Power Supply Replacement: 步骤 18 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 18 中的图像 2,2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X Power Supply Replacement, Disconnect the power button cable: 步骤 19 中的图像 1,3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: 步骤 19 中的图像 2,3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: 步骤 19 中的图像 3,3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Power Supply Replacement, Remove the chassis screws: 步骤 20 中的图像 1,1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Power Supply Replacement, Peel up the USB port cable: 步骤 21 中的图像 1,2 Xbox Series X Power Supply Replacement, Peel up the USB port cable: 步骤 21 中的图像 2,2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Power Supply Replacement, Remove the center chassis assembly: 步骤 22 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: 步骤 22 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: 步骤 22 中的图像 3,3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Power Supply Replacement, Unlatch the chassis strap: 步骤 23 中的图像 1,3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: 步骤 23 中的图像 2,3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: 步骤 23 中的图像 3,3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Power Supply Replacement: 步骤 24 中的图像 1,3 Xbox Series X Power Supply Replacement: 步骤 24 中的图像 2,3 Xbox Series X Power Supply Replacement: 步骤 24 中的图像 3,3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Power Supply Replacement, Remove the power cable port: 步骤 25 中的图像 1,1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Power Supply Replacement: 步骤 26 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 26 中的图像 2,2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Power Supply Replacement, De-route the power cables: 步骤 27 中的图像 1,2 Xbox Series X Power Supply Replacement, De-route the power cables: 步骤 27 中的图像 2,2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Power Supply Replacement: 步骤 28 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 28 中的图像 2,2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Power Supply Replacement, Remove the corner cover: 步骤 29 中的图像 1,1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Power Supply Replacement: 步骤 30 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 30 中的图像 2,2
    在这个步骤中使用的工具:
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Power Supply Replacement, Remove the accessory antenna board: 步骤 31 中的图像 1,1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Power Supply Replacement: 步骤 32 中的图像 1,3 Xbox Series X Power Supply Replacement: 步骤 32 中的图像 2,3 Xbox Series X Power Supply Replacement: 步骤 32 中的图像 3,3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Xbox Series X Power Supply Replacement, Remove the board shield: 步骤 33 中的图像 1,1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Power Supply Replacement: 步骤 34 中的图像 1,3 Xbox Series X Power Supply Replacement: 步骤 34 中的图像 2,3 Xbox Series X Power Supply Replacement: 步骤 34 中的图像 3,3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Power Supply Replacement, Remove the chassis strap: 步骤 35 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the chassis strap: 步骤 35 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the chassis strap: 步骤 35 中的图像 3,3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Power Supply Replacement: 步骤 36 中的图像 1,2 Xbox Series X Power Supply Replacement: 步骤 36 中的图像 2,2
    • Remove the chassis strap.
  37. Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: 步骤 37 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: 步骤 37 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: 步骤 37 中的图像 3,3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: 步骤 38 中的图像 1,3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: 步骤 38 中的图像 2,3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: 步骤 38 中的图像 3,3
    • Grip and compress the locking tab on the 2-pin power connector.
  39. Xbox Series X Power Supply Replacement, Open the cable guide: 步骤 39 中的图像 1,2 Xbox Series X Power Supply Replacement, Open the cable guide: 步骤 39 中的图像 2,2
    • Open the lid on the power supply's plastic cable guide.
  40. Xbox Series X Power Supply Replacement, Remove the power supply screws: 步骤 40 中的图像 1,2 Xbox Series X Power Supply Replacement, Remove the power supply screws: 步骤 40 中的图像 2,2
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
  41. Xbox Series X Power Supply Replacement, Remove the power supply: 步骤 41 中的图像 1,2 Xbox Series X Power Supply Replacement, Remove the power supply: 步骤 41 中的图像 2,2
    • Remove the power supply.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
35等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
155,514 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,638篇指南
29指南评论
So, I am a skilled DIYer. I had 1 series x that had no power all the sudden, under warranty, sent back and received a refurb. Then I got a halo infinite edition, it all the sudden wouldn't send video. It would power up but I couldn't boot in safe mode or low res mode. Sent it back, send me a refurb. Now my brothers Xbox did the same thing. It turns on but never boots then shuts off after few minutes. No controller connects either, and can't have the xbox sync with the flash. His is not under warranty so I bought a PSU and replaced, still same thing. Any ideas? Microsoft just sends you a refurb and doesn't tell you what was wrong or else I'd know since it happened to my infinite console.
heavychevy9 - 回复
Have you tried replacing the SSD drive?
Kason M -
FYI this guide is amazing! Down to providing the length of screws and circling in photos. A++
heavychevy9 - 回复
Well ladies and gentlemen I did it. Took about an hour and a half, only because I put one of the cables on backwards, otherwise it would have only taken an hour. SHES ALIVE!!!! Thank you so much to the person that created these instructions they were SPOT ON!
CAN I GET A A'MEN!!!
Jake Burton - 回复
It just worked for me too! Took me about 2 hours, but I tend to work on this stuff extra slowly to be careful. Thanks so much!
Jon Aron - 回复
添加评论
浏览统计数据:
过去 24 小时: 74
过去 7 天: 638
过去 30 天: 2,246
总计 80,494
