跳转到主内容
加入维修社区 - 创建账户
Xbox One Kinect Outer Shell Replacement
你所需要的
  1. Xbox One Kinect Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    询问修复机器人
    添加评论
  2. Xbox One Kinect Outer Shell Replacement: 步骤 2 中的图像 1,3 Xbox One Kinect Outer Shell Replacement: 步骤 2 中的图像 2,3 Xbox One Kinect Outer Shell Replacement: 步骤 2 中的图像 3,3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    询问修复机器人
    添加评论
  3. Xbox One Kinect Outer Shell Replacement: 步骤 3 中的图像 1,3 Xbox One Kinect Outer Shell Replacement: 步骤 3 中的图像 2,3 Xbox One Kinect Outer Shell Replacement: 步骤 3 中的图像 3,3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G3
4 名成员
创作了7篇指南
1指南评论
Again, another great guide, guys. Also, this is a solid prerequisite. I noticed when reviewing this one that you did a good job of indicating which tools to use and when. Your markup is clear and concise, and your writing is not overly technical and complicated. Your photos and action steps are also very clear. You did a great job this semester!
P.S. -- I'm not sure if we're actually supposed to post our reviews as comments here. You may not want them on your guides! If I'm mistaken here, don't hesitate to remove them. I'm submitting through Canvas as well.
Noah Hickerson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 48
总计 3,014
