跳转到主内容
加入维修社区 - 创建账户
Xbox One Kinect LED Sensor Replacement
你所需要的
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    询问修复机器人
    添加评论
  2. Xbox One Kinect LED Sensor Replacement: 步骤 2 中的图像 1,3 Xbox One Kinect LED Sensor Replacement: 步骤 2 中的图像 2,3 Xbox One Kinect LED Sensor Replacement: 步骤 2 中的图像 3,3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    询问修复机器人
    添加评论
  3. Xbox One Kinect LED Sensor Replacement: 步骤 3 中的图像 1,3 Xbox One Kinect LED Sensor Replacement: 步骤 3 中的图像 2,3 Xbox One Kinect LED Sensor Replacement: 步骤 3 中的图像 3,3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    询问修复机器人
    添加评论
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 步骤 4 中的图像 1,3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 步骤 4 中的图像 2,3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 步骤 4 中的图像 3,3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G3
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 39
总计 1,567
