跳转到主内容
Xbox 360 Wireless Controller Right Analog Stick Replacement
你所需要的
  1. Xbox 360 Wireless Controller Right Analog Stick Replacement, Right Analog Stick: 步骤 1 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement, Right Analog Stick: 步骤 1 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement, Right Analog Stick: 步骤 1 中的图像 3,3
    • Here is the controller that will get new analog sticks.
    • Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
    • Use tweezers or similar instrument, to peel the barcode sticker from the battery compartment.ove the battery holder from the controller.
  2. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 2 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 2 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 2 中的图像 3,3
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a plastic opening tool between the front and rear cases along the left edge of the controller. Rotate the tool toward the front of the controller to pry the two cases apart.
    • Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  3. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 3 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 3 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 3 中的图像 3,3
    • Tilt the bottom case slightly toward the trigger buttons to slide it off the top case
    • Here is a view of the inside of the controller. Note the vibration motors having different counter weights.
    • Remove the connector from the left motor (controller is positioned upside down, left controller will be shown right etc.)
  4. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 4 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 4 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 4 中的图像 3,3
    • Remove the connector from the right motor
    • Both motors are disconnected. Notice position of the motors inside the case for re-assembly.
    • Remove logic board
  5. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 5 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 5 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 5 中的图像 3,3
    • Notice placement of rubber membranes of the front case for reassembly.
    • To remove the covers of the analogs sticks, simply pull them of the mounting pegs.
    • Turn the logic board over and find the 14 solder connections
  6. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 6 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 6 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 6 中的图像 3,3
    • Apply some Flux on a desoldering wick
    • Unsolder the connections using a soldering iron and the wick.
    • Stay clear of the small SMD components that may surround the solder pads.
  7. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 7 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 7 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 7 中的图像 3,3
    • All contacts have been desoldered.
    • Gently try to remove the analog stick, making sure that all points can easily be moved off the board
    • If properly desoldered, the analog stick should clear the board without difficulty
  8. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 8 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 8 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 8 中的图像 3,3
    • Remove the analog stick
    • Always make sure that the replacement will fit. Make sure it has the same contacts and dimensions.
    • Place the new analog stick through the holes on the board. Make sure that it is flush with the board.
  9. Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 9 中的图像 1,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 9 中的图像 2,3 Xbox 360 Wireless Controller Right Analog Stick Replacement: 步骤 9 中的图像 3,3
    • Apply flux to all contacts before soldering. I use flux even though my solder contains it as well.
    • Apply solder to all the 14 contacts. Make sure that there is a good bond between the contacts of the analog stick and the solder pads on the board.
    • Here all 14 contacts have been soldered. All that is left now is to wash of the flux with some isopropyl alcohol and to reassemble the controller.
结论
12等其他人完成本指南。
oldturkey03
于09/29/10注册
732,485 声望
创作了116篇指南
团队
Global Fixers Global Fixers 的会员
Community
22 名成员
创作了285篇指南
7条评论
hey i changed my analog stick (the right one) but for some reason it still does not work. its as if some one is pushing the analog stick to the right but the controller is not being touched. all other buttons work as they should. i even used two different analog sticks and for some reason it still doesn't work. any suggestions?
Ariel Mairzadeh - 回复
did you find the solution? two of mine ended up that way
johnking -
can I use analog stick from old control?
Ahmed - 回复
@ahmed_jabbar Yes you can but it may be wore out too. Consider to replace it with a new one to have it guaranteed working.
oldturkey03 -
I mean from xboxclassic control
Ahmed -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 111
总计 23,640
