简介
Use this guide to replace the bottom panel of your controller that you cracked by throwing it at the TV.
你所需要的
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
20等其他人完成本指南。
2指南评论
I have 2 remote controllers of X box one which is not working.
Ib rb button
Abdou Fegas - 回复 分享
