跳转到主内容
加入维修社区 - 创建账户
Xbox 360 E Button Board Replacement
你所需要的
  1. Xbox 360 E Button Board Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  2. Xbox 360 E Button Board Replacement: 步骤 2 中的图像 1,1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  3. Xbox 360 E Button Board Replacement: 步骤 3 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 3 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    询问修复机器人
    添加评论
  4. Xbox 360 E Button Board Replacement, Bottom Panel: 步骤 4 中的图像 1,1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  5. Xbox 360 E Button Board Replacement: 步骤 5 中的图像 1,2 Xbox 360 E Button Board Replacement: 步骤 5 中的图像 2,2
    • Slide the spudger along the crevice to separate the grated face and the top body.
    询问修复机器人
    添加评论
  6. Xbox 360 E Button Board Replacement: 步骤 6 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 6 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 6 中的图像 3,3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
    询问修复机器人
    添加评论
  7. Xbox 360 E Button Board Replacement, Front Panel: 步骤 7 中的图像 1,3 Xbox 360 E Button Board Replacement, Front Panel: 步骤 7 中的图像 2,3 Xbox 360 E Button Board Replacement, Front Panel: 步骤 7 中的图像 3,3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    添加评论
  8. Xbox 360 E Button Board Replacement: 步骤 8 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 8 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 8 中的图像 3,3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    询问修复机器人
    添加评论
  9. Xbox 360 E Button Board Replacement: 步骤 9 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 9 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 9 中的图像 3,3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    添加评论
  10. Xbox 360 E Button Board Replacement: 步骤 10 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 10 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 10 中的图像 3,3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
    询问修复机器人
    添加评论
  11. Xbox 360 E Button Board Replacement: 步骤 11 中的图像 1,2 Xbox 360 E Button Board Replacement: 步骤 11 中的图像 2,2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
    询问修复机器人
    添加评论
  12. Xbox 360 E Button Board Replacement: 步骤 12 中的图像 1,3 Xbox 360 E Button Board Replacement: 步骤 12 中的图像 2,3 Xbox 360 E Button Board Replacement: 步骤 12 中的图像 3,3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    询问修复机器人
    添加评论
  13. Xbox 360 E Button Board Replacement, Button Board: 步骤 13 中的图像 1,3 Xbox 360 E Button Board Replacement, Button Board: 步骤 13 中的图像 2,3 Xbox 360 E Button Board Replacement, Button Board: 步骤 13 中的图像 3,3
    • Rotate the front panel so you are looking at the inside of the piece.
    • Unscrew the six 6 mm screws with the T6 Torx screwdriver.
    • Carefully pull the green plate up and off to remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Jennifer
于02/02/14注册
2,287 声望
创作了4篇指南
团队
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G11
4 名成员
创作了55篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 36
过去 30 天: 212
总计 15,127
