跳转到主内容
加入维修社区 - 创建账户
XPS M2010 MXP061 Memory Module Replacement
你所需要的
    1. XPS M2010 MXP061 Memory Module Replacement, Memory Cover Remove: 步骤 1 中的图像 1,1
      • CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide .
      • NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface. If you leave the area, ground yourself again when you return to the computer.
      • NOTE: Memory modules purchased from Dell are covered under your computer warranty.
      • NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
      • NOTICE: To help prevent damage to the system board, you must remove the main battery before you begin working inside the computer
      • With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
      询问修复机器人
      添加评论
    2. XPS M2010 MXP061 Memory Module Replacement, Removing Securing Clamps: 步骤 2 中的图像 1,1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      询问修复机器人
      添加评论
    3. XPS M2010 MXP061 Memory Module Replacement, Removeing memory Module: 步骤 3 中的图像 1,1
      • Remove the module from the connector on the system board.
      询问修复机器人
      添加评论
    4. XPS M2010 MXP061 Memory Module Replacement, Replacing the Memory Module: 步骤 4 中的图像 1,1
      • Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
      询问修复机器人
      添加评论
    5. XPS M2010 MXP061 Memory Module Replacement, Seating the Memory Module in place.: 步骤 5 中的图像 1,1
      • Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      询问修复机器人
      添加评论
    6. XPS M2010 MXP061 Memory Module Replacement, Replace the memory cover: 步骤 6 中的图像 1,1
      • Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了8,882篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 46
总计 644
