跳转到主内容
加入维修社区 - 创建账户
X230T RAM Replacement
你所需要的
  1. X230T RAM Replacement, Removing the battery: 步骤 1 中的图像 1,1
    • Start by removing the battery from the laptop. The battery should be removed to prevent damaging the motherboard when the RAM is installed and removed.
    • Slide the latch on the left to the left, and hold the other latch on the right to the right.
    • Slide out the battery, it should come out effortlessly.
    询问修复机器人
    添加评论
  2. X230T RAM Replacement, Removing the RAM cover: 步骤 2 中的图像 1,1
    • Undo the two screws that are circled, then, pry the RAM cover off by placing your finger nail or a spudger between the laptop and the RAM cover and puling up.
    询问修复机器人
    添加评论
  3. X230T RAM Replacement, Removing RAM: 步骤 3 中的图像 1,3 X230T RAM Replacement, Removing RAM: 步骤 3 中的图像 2,3 X230T RAM Replacement, Removing RAM: 步骤 3 中的图像 3,3
    • Remove the two clips from the RAM by pulling them slowly in the direction shown by the red arrows. When both clips are released, the RAM will lift up at a 45 degree angle (picture 2).
    • Once the RAM is at the angle as shown in picture 2, remove the RAM by pulling it out of the computer, as shown by the orange arrow.
    • If required, repeat the procedure for the other RAM module. The steps are the same.
    询问修复机器人
    添加评论
  4. X230T RAM Replacement, Installing RAM: 步骤 4 中的图像 1,3 X230T RAM Replacement, Installing RAM: 步骤 4 中的图像 2,3 X230T RAM Replacement, Installing RAM: 步骤 4 中的图像 3,3
    • To install the RAM, insert the new RAM with the notch on the RAM lining up to the notch on the slot. Slide the RAM in on a 45 degree angle as shown in picture 1.
    • Firmly push down the RAM until it is locked in place by the clips on either side. The clips will move around the RAM when the RAM is being inserted.
    • Put on the cover with the clips going in to the bottom edge of the cover first, then, tighten up the screws on the RAM cover.
    • Install the battery in to the computer, making sure the locking clips are engaged, and power the computer on.
    • Check the BIOS or your operating system to verify the RAM is working.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 1,383
