跳转到主内容
加入维修社区 - 创建账户
Whirlpool Refrigerator Start Relay Assembly Replacement
你所需要的
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    询问修复机器人
    添加评论
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
    询问修复机器人
    添加评论
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Pull the rear panel off the chassis to remove it.
    询问修复机器人
    添加评论
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
    询问修复机器人
    添加评论
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 3,3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
    询问修复机器人
    添加评论
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 3,3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
    询问修复机器人
    添加评论
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 3,3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
5等其他人完成本指南。
nicO
于04/14/15注册
15,990 声望
创作了89篇指南
3指南评论
Is it universal part
dyannatorres@yahoo.com - 回复 分享
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO - 回复 分享
Last part is not clear about where to put multimeter probes for testing each component. It makes the whole exercise useless.
Shafeeq Qaiser - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 102
过去 30 天: 496
总计 16,771
