跳转到主内容
加入维修社区 - 创建账户
Whirlpool Refrigerator Door Sensor Replacement
你所需要的
    1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 1,3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 2,3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 3,3
      • Depending on your repair, open one or both doors.
      询问修复机器人
      添加评论
    1. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 3,3
      • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
      • Pry up to separate the door sensor enough so you can grip it with your fingers.
      询问修复机器人
      添加评论
    2. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 步骤 3 中的图像 2,2
      • Pull the door sensor through the chassis enough to access its connectors.
      • Disconnect any connectors attached to the door sensor.
      • Remove the door sensor.
      询问修复机器人
      添加评论
    3. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 步骤 4 中的图像 2,2
      • If you own a multimeter, you can test your door sensor's resistance.
      • Set the multimeter to the resistance or continuity measurement mode.
      • With the button in its neutral position, the multimeter should read "OL."
      • With the button pressed, the multimeter should read around 0Ω.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
nicO
于04/14/15注册
15,990 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 182
总计 5,280
