跳转到主内容
Whirlpool Refrigerator Dispenser Assembly Replacement
你所需要的
  1. Whirlpool Refrigerator Dispenser Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 1,2 Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 2,2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 3,3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the control board: 步骤 4 中的图像 1,1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Dispenser Assembly Replacement: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement: 步骤 5 中的图像 3,3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 3,3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the control board: 步骤 7 中的图像 1,1
    • Remove the control board.
  8. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 步骤 8 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 步骤 8 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 步骤 8 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  9. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 步骤 9 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 步骤 9 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 步骤 9 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  10. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: 步骤 10 中的图像 1,2 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: 步骤 10 中的图像 2,2
    • Reposition the cables so they lay in front of the top plastic clip.
  11. Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 11 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 11 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 11 中的图像 3,3
    • Depending on your device, the amount of plastic clips that secure the dispenser assembly can vary.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clips to completely separate the dispenser assembly from the chassis.
  12. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: 步骤 12 中的图像 1,2 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: 步骤 12 中的图像 2,2
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  13. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 13 中的图像 1,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 13 中的图像 2,3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 13 中的图像 3,3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  14. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser assembly: 步骤 14 中的图像 1,1
    • Remove the dispenser assembly.
  15. Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: 步骤 15 中的图像 1,2 Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: 步骤 15 中的图像 2,2
    • If you own a multimeter, you can test your solenoid's resistance.
    • With the button in its neutral position, the multimeter should read "open circuit" or "OL."
    • With the button pressed, the multimeter should read close to 0Ω.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
2条评论
The bottom side of refrigeration is not working but the top inversely working the cooling process
Dawit Muluneh - 回复
I'd take a look at one of two troubleshooting pages:
Freezer Not Freezing or Refrigerator Not Cooling
nicO -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 69
总计 238
