跳转到主内容
加入维修社区 - 创建账户
Watch Battery Replacement
你所需要的
    1. Watch  Battery Replacement, Battery: 步骤 1 中的图像 1,2 Watch  Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • Place your watch in the watch holder, and adjust the sizing screw to the appropriate size for your watch.
      • If you do not have a holder, you can hold the watch yourself and still be able to complete the repair.
      询问修复机器人
      添加评论
    2. Watch  Battery Replacement: 步骤 2 中的图像 1,1
      • Next, you will have to adjust the dimensions of the watch back remover tool you will use to take the watch back off. The dimensions should be set so the tool properly fits the three connection points on the back of the watch. You can do this by screwing or unscrewing the adjustment screws on the tool.
      询问修复机器人
      添加评论
    3. Watch  Battery Replacement: 步骤 3 中的图像 1,1
      • Turn the tool counterclockwise until the back of the watch is completely off.
      • You will need to hold the watch band up while you complete this step.
      询问修复机器人
      添加评论
    4. Watch  Battery Replacement: 步骤 4 中的图像 1,2 Watch  Battery Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to carefully remove the current watch battery. Next, place the new battery in the same spot and orientation you removed the previous battery from.
      • Do not touch or remove any other piece inside of the watch.
      询问修复机器人
      添加评论
    5. Watch  Battery Replacement: 步骤 5 中的图像 1,1
      • Place the back of the watch back on and align the watch back remover tool to the three connection points. Then, turn the tool clockwise until the back of the watch is tightly secured.
      询问修复机器人
      添加评论
    6. Watch  Battery Replacement: 步骤 6 中的图像 1,1
      • Check the watch for proper operation and set it to the correct time.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Maria Pina
于09/11/15注册
217 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 98
总计 3,149
