跳转到主内容
加入维修社区 - 创建账户
Wacom Intuos4 Express Keys Replacement
你所需要的
    1. Wacom Intuos4 Express Keys Replacement, Casing: 步骤 1 中的图像 1,3 Wacom Intuos4 Express Keys Replacement, Casing: 步骤 1 中的图像 2,3 Wacom Intuos4 Express Keys Replacement, Casing: 步骤 1 中的图像 3,3
      • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
      • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
      询问修复机器人
      添加评论
    2. Wacom Intuos4 Express Keys Replacement: 步骤 2 中的图像 1,2 Wacom Intuos4 Express Keys Replacement: 步骤 2 中的图像 2,2
      • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
      • Separate the outer casing from the rest of the tablet.
      询问修复机器人
      添加评论
    1. Wacom Intuos4 Express Keys Replacement, Express Keys: 步骤 3 中的图像 1,3 Wacom Intuos4 Express Keys Replacement, Express Keys: 步骤 3 中的图像 2,3 Wacom Intuos4 Express Keys Replacement, Express Keys: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • Lift yellow tape covering the flat wires with a pair of tweezers.
      • Lift the black plastic clip holding the flat wire to the connector.
      • This should be done with a plastic tool to avoid damaging the contacts.
      • Pull on the white plastic tab to disconnect the flat wire.
      • Do this for the left and right express key chips.
      询问修复机器人
      添加评论
    2. Wacom Intuos4 Express Keys Replacement: 步骤 4 中的图像 1,1
      • Pull the black plastic clip away from the flat wire connector, and pull the flat wire out.
      • It may be easier to pull with a tool on one side, and with your hand on the other at the same time.
      询问修复机器人
      添加评论
    3. Wacom Intuos4 Express Keys Replacement: 步骤 5 中的图像 1,1
      • Use a #1 Phillips head screwdriver to unscrew the four 5mm screws on the express key board you want to replace.
      询问修复机器人
      添加评论
    4. Wacom Intuos4 Express Keys Replacement: 步骤 6 中的图像 1,2 Wacom Intuos4 Express Keys Replacement: 步骤 6 中的图像 2,2
      • Lift the board and rubber buttons up from the case.
      • Separate the rubber buttons from the board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 37
总计 674
