跳转到主内容
加入维修社区 - 创建账户
Wacom Cintiq 24HD Display Control Buttons Replacement
你所需要的
  1. Wacom Cintiq 24HD Display Control Buttons Replacement, Stand: 步骤 1 中的图像 1,1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
    询问修复机器人
    添加评论
  2. Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 2 中的图像 1,3 Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 2 中的图像 2,3 Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 2 中的图像 3,3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
    询问修复机器人
    添加评论
  3. Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 3 中的图像 1,1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
    询问修复机器人
    添加评论
  4. Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 步骤 4 中的图像 1,3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 步骤 4 中的图像 2,3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 步骤 4 中的图像 3,3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
    询问修复机器人
    添加评论
  5. Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 5 中的图像 1,2 Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 5 中的图像 2,2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
    询问修复机器人
    添加评论
  6. Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 步骤 6 中的图像 1,3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 步骤 6 中的图像 2,3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 步骤 6 中的图像 3,3
    • Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
    • Remove metal holding plate by lifting up and off of the button board.
    询问修复机器人
    添加评论
  7. Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the button board by pinching the wiring close to the connector and gently pulling straight out from the port.
    询问修复机器人
    添加评论
  8. Wacom Cintiq 24HD Display Control Buttons Replacement: 步骤 8 中的图像 1,1
    • Remove the button cover by pushing the buttons out of their holes and pulling the cover up.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Jay Sung
于10/08/18注册
481 声望
创作了4篇指南
团队
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018 的会员
CPSU-WHITE-F18S15G3
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 1,995
