跳转到主内容
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
你所需要的
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 步骤 1 中的图像 1,2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: 步骤 2 中的图像 1,1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 步骤 3 中的图像 1,2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 步骤 3 中的图像 2,2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 步骤 4 中的图像 1,3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 步骤 4 中的图像 2,3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 步骤 4 中的图像 3,3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: 步骤 5 中的图像 1,1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 步骤 6 中的图像 1,3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 步骤 6 中的图像 2,3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 步骤 6 中的图像 3,3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
结论
Arthur Shi
于01/03/18注册
257,458 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 43
总计 3,102
