跳转到主内容
Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
你所需要的
  1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: 步骤 1 中的图像 1,2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: 步骤 2 中的图像 1,2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: 步骤 2 中的图像 2,2
    • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
    • Use a 3/4" wrench to remove the two nuts securing the handle.
    • Use your palm to push against the shockmount to prevent it from slipping.
    • Remove the nuts and washers and retain them for reassembly.
  3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 步骤 3 中的图像 1,3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 步骤 3 中的图像 2,3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 步骤 3 中的图像 3,3
    • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
    • Slide the guide handle down enough to access the shockmounts.
  4. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: 步骤 4 中的图像 1,2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: 步骤 4 中的图像 2,2
    • Pull the shockmount out of the guide handle.
结论
Arthur Shi
于01/03/18注册
313,851 声望
创作了729篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 742
