跳转到主内容
加入维修社区 - 创建账户
Vtech Move and Crawl Ball Light Up Buttons Replacement
你所需要的
    1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Battery: 步骤 1 中的图像 1,2 Vtech Move and Crawl Ball Light Up Buttons Replacement, Battery: 步骤 1 中的图像 2,2
      • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
      询问修复机器人
      添加评论
    2. Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 2 中的图像 1,3 Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 2 中的图像 2,3 Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 2 中的图像 3,3
      • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
      询问修复机器人
      添加评论
    1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: 步骤 3 中的图像 1,3 Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: 步骤 3 中的图像 2,3 Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: 步骤 3 中的图像 3,3
      • Remove 6 screws in order to pop off the outer shell and reach the inside components.
      询问修复机器人
      添加评论
    2. Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 4 中的图像 1,3 Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 4 中的图像 2,3 Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 4 中的图像 3,3
      • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
      • Make sure the motor is aligned over the correct holes during reassembly.
      询问修复机器人
      添加评论
    1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: 步骤 5 中的图像 1,3 Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: 步骤 5 中的图像 2,3 Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: 步骤 5 中的图像 3,3
      • When the white cover and the ball motor have been removed, the 6 push buttons will be easily accessible. 3 of the buttons can be removed from their slots by gently pulling up on each. The other 3 buttons are located lower in the unit and are held in by 1 phillips screw each.
      • When reassembling ensure that the button is in the inner slot circled in the picture with the button, and shown by the arrows with the button removed.
      询问修复机器人
      添加评论
    2. Vtech Move and Crawl Ball Light Up Buttons Replacement: 步骤 6 中的图像 1,1
      • The button which is being replaced needs to be disconnected from the motherboard using the soldering iron. The replacement should be soldered into the same place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Steven Ivanov
于09/11/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 2-1, Sullivan Fall 2015 USF Tampa, Team 2-1, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 1,019
