简介
If your Voluas VL001 pet feeder is having problems with portion control, you may have an issue with your portion switch. The portion switch is a small electronic switch that gets activated as the main drive gear turns, letting the motherboard know how much food was dispensed.
This replacement requires special skills like wire stripping and soldering.
你所需要的
Remove the lid to the storage tank by using the latch and lifting off.
Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
Place your pet feeder upside down.
Squeeze the lock and remove the battery cover.
Remove the three 1.5V D alkaline batteries.
Insert a metal spudger under the adhesive part of each rubber foot.
Pry the foot off.
Remove the two 11.1 mm screws that secure the switch to the device using a Phillips #2 screwdriver.
Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
You will want to see a score line in the insulation all around the wire like this.
Pull the end of the insulation off, exposing the wire.
