跳转到主内容
加入维修社区 - 创建账户
Vivitar DVR 781HD Screen Replacement
你所需要的
    1. Vivitar DVR 781HD Screen Replacement, Front Case: 步骤 1 中的图像 1,3 Vivitar DVR 781HD Screen Replacement, Front Case: 步骤 1 中的图像 2,3 Vivitar DVR 781HD Screen Replacement, Front Case: 步骤 1 中的图像 3,3
      • Begin with the camcorder lens up on a clear working surface.
      • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
      询问修复机器人
      添加评论
    2. Vivitar DVR 781HD Screen Replacement: 步骤 2 中的图像 1,1
      • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
      询问修复机器人
      添加评论
    3. Vivitar DVR 781HD Screen Replacement: 步骤 3 中的图像 1,3 Vivitar DVR 781HD Screen Replacement: 步骤 3 中的图像 2,3 Vivitar DVR 781HD Screen Replacement: 步骤 3 中的图像 3,3
      • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
      • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
      询问修复机器人
      添加评论
    1. Vivitar DVR 781HD Screen Replacement, Motherboard: 步骤 4 中的图像 1,2 Vivitar DVR 781HD Screen Replacement, Motherboard: 步骤 4 中的图像 2,2
      • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
      询问修复机器人
      添加评论
    2. Vivitar DVR 781HD Screen Replacement: 步骤 5 中的图像 1,1
      • Gently lift the motherboard, handling it by the edges.
      询问修复机器人
      添加评论
    1. Vivitar DVR 781HD Screen Replacement, Screen: 步骤 6 中的图像 1,2 Vivitar DVR 781HD Screen Replacement, Screen: 步骤 6 中的图像 2,2
      • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
      询问修复机器人
      添加评论
    2. Vivitar DVR 781HD Screen Replacement: 步骤 7 中的图像 1,2 Vivitar DVR 781HD Screen Replacement: 步骤 7 中的图像 2,2
      • Turn the motherboard and screen over.
      • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
      询问修复机器人
      添加评论
    3. Vivitar DVR 781HD Screen Replacement: 步骤 8 中的图像 1,1
      • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S54G6
3 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 32
总计 980
