跳转到主内容
加入维修社区 - 创建账户
Visioneer OneTouch 7400 USB Belt Replacement
你所需要的
    1. Visioneer OneTouch 7400 USB Belt Replacement, Outer Case: 步骤 1 中的图像 1,1
      • On the bottom of the scanner, remove the screw at the top left side.
      询问修复机器人
      添加评论
    2. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 2 中的图像 1,2 Visioneer OneTouch 7400 USB Belt Replacement: 步骤 2 中的图像 2,2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      询问修复机器人
      添加评论
    3. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 3 中的图像 1,3 Visioneer OneTouch 7400 USB Belt Replacement: 步骤 3 中的图像 2,3 Visioneer OneTouch 7400 USB Belt Replacement: 步骤 3 中的图像 3,3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      询问修复机器人
      添加评论
    4. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 4 中的图像 1,1
      • Separate the two casement pieces.
      询问修复机器人
      添加评论
    1. Visioneer OneTouch 7400 USB Belt Replacement, Belt: 步骤 5 中的图像 1,1
      • Remove the screw holding the tension spring in place.
      询问修复机器人
      添加评论
    2. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 6 中的图像 1,1
      • Use the plastic opening tool to lift up the tension spring.
      • Be careful. The spring will fly.
      询问修复机器人
      添加评论
    3. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 7 中的图像 1,1
      • Remove the belt from the spool.
      • The spool is a loose piece; don't lose it.
      询问修复机器人
      添加评论
    4. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 8 中的图像 1,1
      • Loosen the belt enough to turn over the sensor bar.
      询问修复机器人
      添加评论
    5. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 9 中的图像 1,2 Visioneer OneTouch 7400 USB Belt Replacement: 步骤 9 中的图像 2,2
      • With the sensor bar turned upside down, remove the screw in the middle of the bar.
      • Lift off the metal plate if it does not come away with the screw.
      询问修复机器人
      添加评论
    6. Visioneer OneTouch 7400 USB Belt Replacement: 步骤 10 中的图像 1,1
      • Carefully lift the belt out of the groove in the sensor bar to remove.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jena
于10/18/13注册
608 声望
创作了6篇指南
团队
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 的会员
UMAINE-DIAZ-F13S1G13
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 605
