跳转到主内容
加入维修社区 - 创建账户
Viola String Replacement
  1. Viola String Replacement, String: 步骤 1 中的图像 1,1
    • Turn the tuning peg belonging to the string you want to replace.
    • Pegs on the left side (C, G) of the viola require you to turn clockwise to loosen, and pegs on the right side (D, A) turn counterclockwise to loosen.
    • Make sure to turn the peg in the correct direction. Accidentally tightening the strings too much may cause it to snap.
    询问修复机器人
    添加评论
  2. Viola String Replacement: 步骤 2 中的图像 1,2 Viola String Replacement: 步骤 2 中的图像 2,2
    • Gently remove the string from the scroll side of the viola, then remove the opposite side of the string from the fine tuner area.
    询问修复机器人
    添加评论
  3. Viola String Replacement: 步骤 3 中的图像 1,1
    • Insert the new string into the peg hole.
    • Make sure the hole is in the correct area and that the inserted string does not overlap other strings. For example, the C string hole should be to the left of the G string.
    询问修复机器人
    添加评论
  4. Viola String Replacement: 步骤 4 中的图像 1,1
    • Turn the tuning peg slowly to tighten the newly inserted string.
    • If the string has a coloured tip, turn the peg until all the colour is wound up.
    • Do not worry about snapping the string in this step. The ball side of the string has not been inserted so there is no risk.
    询问修复机器人
    添加评论
  5. Viola String Replacement: 步骤 5 中的图像 1,2 Viola String Replacement: 步骤 5 中的图像 2,2
    • Insert the ball side of the string into the fine tuner area. If the string does not reach, loosen the tuning peg until it slides in easily. Make sure to also align the string with the bridge.
    询问修复机器人
    添加评论
  6. Viola String Replacement: 步骤 6 中的图像 1,2 Viola String Replacement: 步骤 6 中的图像 2,2
    • After the string has been inserted, begin slowly tuning the string by turning the pegs.
    • Try to tune a pitch lower using the pegs, then use the fine tuners to fully tune the string.
    • Be careful, the string may snap if tightened too much. Try using the advice above to avoid this.
    询问修复机器人
    添加评论
  7. Viola String Replacement: 步骤 7 中的图像 1,1
    • Gently tug the newly inserted string to make sure it is secured. If it slides off the bridge, it is not tightened enough.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
Irene Shang Yun Yang
于05/24/23注册
145 声望
撰写一个指南
团队
York University, Team A-9, Allen Summer 2023 York University, Team A-9, Allen Summer 2023 的会员
YORK-ALLEN-SU23SAG9
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 639
