跳转到主内容
加入维修社区 - 创建账户
Vicks FilterFree Plus Touchpad Motherboard Replacement
你所需要的
  1. Vicks FilterFree Plus Touchpad Motherboard Replacement, Tank Cap: 步骤 1 中的图像 1,1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
    询问修复机器人
    添加评论
  2. Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 2 中的图像 1,2 Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 2 中的图像 2,2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
    询问修复机器人
    添加评论
  3. Vicks FilterFree Plus Touchpad Motherboard Replacement, Touchpad Motherboard: 步骤 3 中的图像 1,2 Vicks FilterFree Plus Touchpad Motherboard Replacement, Touchpad Motherboard: 步骤 3 中的图像 2,2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
    询问修复机器人
    添加评论
  4. Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 4 中的图像 1,2 Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 4 中的图像 2,2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
    询问修复机器人
    添加评论
  5. Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 5 中的图像 1,2 Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 5 中的图像 2,2
    • When both wires are followed, one connects to the central hub and the other connects to another smaller circuit board. In order to get to the smaller circuit board, the central one needs to be unscrewed.
    • Remove both screws using a Phillips #1 screwdriver.
    • Lift up the central circuit board.
    询问修复机器人
    添加评论
  6. Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 6 中的图像 1,3 Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 6 中的图像 2,3 Vicks FilterFree Plus Touchpad Motherboard Replacement: 步骤 6 中的图像 3,3
    • Once the central circuit board is lifted, the smaller one can be taken from its holster.
    • After the smaller board is taken out, the wire connecting from the main board to the touchpad motherboard can now be unclipped.
    • Remove the smaller circuit board and the touchpad motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 416
