跳转到主内容
加入维修社区 - 创建账户
Verizon Ellipsis 8 Disassembly
你所需要的
    1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
      询问修复机器人
      添加评论
    2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: 步骤 2 中的图像 1,1
      • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
      • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
      添加评论
    3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 步骤 3 中的图像 1,2 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 步骤 3 中的图像 2,2
      • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
      • You can look at the picture of the rear cover to see where the snaps are located.
      询问修复机器人
      添加评论
    4. Verizon Ellipsis 8 Disassembly, Remove Battery: 步骤 4 中的图像 1,1
      • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
      • There was no adhesive on the back of the battery, just along the sides.
      添加评论
    5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 步骤 5 中的图像 1,3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 步骤 5 中的图像 2,3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 步骤 5 中的图像 3,3
      • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
      • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
      • **Be careful with the antenna cable!**
      添加评论
    6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: 步骤 6 中的图像 1,1
      • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
      • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
      添加评论
结论
取消:我没有完成这个指南。
31等其他人完成本指南。
SMcC21985
于11/10/15注册
1,271 声望
创作了2篇指南
4指南评论
Keith Brockley - 回复 分享
what size screws are thoze i need to get some i lost some
stacy - 回复 分享
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - 回复 分享
My tablet is on working, when I press to get is frozen, it doesn't let me in
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 57
总计 21,385
