跳转到主内容
加入维修社区 - 创建账户
Velocity Micro Cruz Battery Replacement
你所需要的
    1. Velocity Micro Cruz Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Insert a plastic opening device into the small crack separating the screen and the back of the device.
      • After the back of the device is separated, remove the back and you can now access the battery.
      • When prying the back of the device off, be careful as this could cause small damages or cracks to the screen.
      询问修复机器人
      添加评论
    2. Velocity Micro Cruz Battery Replacement: 步骤 2 中的图像 1,1
      • The battery is connected to the motherboard where the picture indicates.
      • To remove the battery, you must first detach the battery wire connecting it from the motherboard. To do this, simply gently, but firmly, pull it out of the motherboard connector.
      询问修复机器人
      添加评论
    3. Velocity Micro Cruz Battery Replacement: 步骤 3 中的图像 1,1
      • Simply pry the battery out of the device at this point. The battery may be held in place by adhesive glue and require a nylon spudger or plastic opening tool to help pry it out.
      • Place your new battery in place of the old one. Connect the new battery's wire to the motherboard and you are finished.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Texas Tech, Team 12-4, Bennett Fall 2016 Texas Tech, Team 12-4, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G4
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 1,460
