跳转到主内容
加入维修社区 - 创建账户
VTech Write and Learn Creative Center Slider Replacement
你所需要的
    1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: 步骤 1 中的图像 1,3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: 步骤 1 中的图像 2,3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      询问修复机器人
      添加评论
    1. VTech Write and Learn Creative Center Slider Replacement, Slider: 步骤 2 中的图像 1,1
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G2
3 名成员
创作了12篇指南
1指南评论
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 766
