跳转到主内容
加入维修社区 - 创建账户
VTech InnoTab 2s Speaker Replacement
你所需要的
    1. VTech InnoTab 2s Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Turn your device to where the back panel is facing you.
      询问修复机器人
      添加评论
    2. VTech InnoTab 2s Speaker Replacement: 步骤 2 中的图像 1,2 VTech InnoTab 2s Speaker Replacement: 步骤 2 中的图像 2,2
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      询问修复机器人
      添加评论
    3. VTech InnoTab 2s Speaker Replacement: 步骤 3 中的图像 1,3 VTech InnoTab 2s Speaker Replacement: 步骤 3 中的图像 2,3 VTech InnoTab 2s Speaker Replacement: 步骤 3 中的图像 3,3
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      询问修复机器人
      添加评论
    4. VTech InnoTab 2s Speaker Replacement: 步骤 4 中的图像 1,2 VTech InnoTab 2s Speaker Replacement: 步骤 4 中的图像 2,2
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      询问修复机器人
      添加评论
    5. VTech InnoTab 2s Speaker Replacement: 步骤 5 中的图像 1,2 VTech InnoTab 2s Speaker Replacement: 步骤 5 中的图像 2,2
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      询问修复机器人
      添加评论
    1. VTech InnoTab 2s Speaker Replacement, Motherboard: 步骤 6 中的图像 1,1
      • First begin by removing the three cross-head screws using a J0 bit.
      询问修复机器人
      添加评论
    2. VTech InnoTab 2s Speaker Replacement: 步骤 7 中的图像 1,1
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      询问修复机器人
      添加评论
    3. VTech InnoTab 2s Speaker Replacement: 步骤 8 中的图像 1,1
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      询问修复机器人
      添加评论
    4. VTech InnoTab 2s Speaker Replacement: 步骤 9 中的图像 1,1
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      询问修复机器人
      添加评论
    5. VTech InnoTab 2s Speaker Replacement: 步骤 10 中的图像 1,1
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      询问修复机器人
      添加评论
    1. VTech InnoTab 2s Speaker Replacement, Speaker: 步骤 11 中的图像 1,1
      • Desolder these two points from the circuit board.
      • A soldering guide provided by iFixit can be found here: Soldering Skills.
      询问修复机器人
      添加评论
    2. VTech InnoTab 2s Speaker Replacement: 步骤 12 中的图像 1,1
      • Remove the two screws that are holding down the speaker.
      询问修复机器人
      添加评论
    3. VTech InnoTab 2s Speaker Replacement: 步骤 13 中的图像 1,1
      • Desolder the two wires that are connected to the speaker.
      • A soldering guide offered by IFIXIT can be found here: Soldering Skills.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 的会员
USFT-LACY-F16S5G1
4 名成员
创作了12篇指南
1指南评论
Thank you for this guide. I have a Vtech (ELC) toy flip phone, which has similar issue. I think your guide is incomplete, has only 13 steps and stops at desoldering the speaker. What speaker shall I get, does it matter, or just the size matters? Thank you!
Scream - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 671
