跳转到主内容
加入维修社区 - 创建账户
VTech InnoTab 2s Power Connector Replacement
你所需要的
  1. VTech InnoTab 2s Power Connector Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn your device to where the back panel is facing you.
    询问修复机器人
    添加评论
  2. VTech InnoTab 2s Power Connector Replacement: 步骤 2 中的图像 1,2 VTech InnoTab 2s Power Connector Replacement: 步骤 2 中的图像 2,2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
    询问修复机器人
    添加评论
  3. VTech InnoTab 2s Power Connector Replacement: 步骤 3 中的图像 1,3 VTech InnoTab 2s Power Connector Replacement: 步骤 3 中的图像 2,3 VTech InnoTab 2s Power Connector Replacement: 步骤 3 中的图像 3,3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
    询问修复机器人
    添加评论
  4. VTech InnoTab 2s Power Connector Replacement: 步骤 4 中的图像 1,2 VTech InnoTab 2s Power Connector Replacement: 步骤 4 中的图像 2,2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
    询问修复机器人
    添加评论
  5. VTech InnoTab 2s Power Connector Replacement: 步骤 5 中的图像 1,2 VTech InnoTab 2s Power Connector Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
    询问修复机器人
    添加评论
  6. VTech InnoTab 2s Power Connector Replacement, Motherboard: 步骤 6 中的图像 1,1
    • First begin by removing the three cross-head screws using a J0 bit.
    询问修复机器人
    添加评论
  7. VTech InnoTab 2s Power Connector Replacement: 步骤 7 中的图像 1,1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
    询问修复机器人
    添加评论
  8. VTech InnoTab 2s Power Connector Replacement: 步骤 8 中的图像 1,1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
    询问修复机器人
    添加评论
  9. VTech InnoTab 2s Power Connector Replacement: 步骤 9 中的图像 1,1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
    询问修复机器人
    添加评论
  10. VTech InnoTab 2s Power Connector Replacement: 步骤 10 中的图像 1,1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
    询问修复机器人
    添加评论
  11. VTech InnoTab 2s Power Connector Replacement, Power Connector: 步骤 11 中的图像 1,1
    • Use a soldering tool to desolder the two highlighted points.
    • A soldering guide offered by IFIXIT can be found here: Soldering Skills.
    询问修复机器人
    添加评论
  12. VTech InnoTab 2s Power Connector Replacement: 步骤 12 中的图像 1,1
    • Use a screwdriver to remove the screw that is holding the power jack in place.
    • Now you have access to remove and replace the power jack.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 的会员
USFT-LACY-F16S5G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 653
