跳转到主内容
加入维修社区 - 创建账户
VTech Baby's Learning Laptop Mode Switch Replacement
你所需要的
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: 步骤 1 中的图像 1,1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      询问修复机器人
      添加评论
    2. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 2 中的图像 1,1
      • Remove the battery door.
      • Take out the batteries.
      询问修复机器人
      添加评论
    3. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 3 中的图像 1,1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      询问修复机器人
      添加评论
    4. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 4 中的图像 1,2 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 4 中的图像 2,2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      添加评论
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 步骤 5 中的图像 1,2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 步骤 5 中的图像 2,2
      • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
      询问修复机器人
      添加评论
    2. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 1,3 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 2,3 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 3,3
      • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
      • Lay the board down gently and out of the way.
      • Take care not to damage any of the wires or the board itself.
      询问修复机器人
      添加评论
    3. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 7 中的图像 1,1
      • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
      • Five 7.3mm
      • Two 6.0mm
      询问修复机器人
      添加评论
    4. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 8 中的图像 1,1
      • Once the screws have been removed, the mode switch assembly can be removed easily.
      • Take care not to misplace the spring indicated in the picture.
      • You need this spring to find a matching replacement if it is in anyway damaged.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 843
