跳转到主内容
加入维修社区 - 创建账户
VHS Shell Replacement
你所需要的
  1. VHS Shell Replacement, Plastic Shell: 步骤 1 中的图像 1,2 VHS Shell Replacement, Plastic Shell: 步骤 1 中的图像 2,2
    • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  2. VHS Shell Replacement: 步骤 2 中的图像 1,1
    • Once the screws are out, pull off the front of the VHS shell.
    • Take off any labels on the sides of tape before doing this step.
    • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
    询问修复机器人
    添加评论
  3. VHS Shell Replacement: 步骤 3 中的图像 1,2 VHS Shell Replacement: 步骤 3 中的图像 2,2
    • Hold down on the white lever.
    • While holding down, carefully take out the reel on the right.
    • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
    询问修复机器人
    添加评论
  4. VHS Shell Replacement: 步骤 4 中的图像 1,2 VHS Shell Replacement: 步骤 4 中的图像 2,2
    • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
    • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
    询问修复机器人
    添加评论
  5. VHS Shell Replacement: 步骤 5 中的图像 1,1
    • Once the screws are out, pull off the front of the replacement shell.
    询问修复机器人
    添加评论
  6. VHS Shell Replacement: 步骤 6 中的图像 1,1
    • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
    • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
    添加评论
  7. VHS Shell Replacement: 步骤 7 中的图像 1,1
    • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
    添加评论
  8. VHS Shell Replacement: 步骤 8 中的图像 1,1
    • Turn the reels to retract any excess tape hanging out of the top.
    • This isn't a necessary step, just one that I prefer to do.
    询问修复机器人
    添加评论
  9. VHS Shell Replacement: 步骤 9 中的图像 1,1
    • Place the top of the replacement shell back on.
    询问修复机器人
    添加评论
  10. VHS Shell Replacement: 步骤 10 中的图像 1,1
    • Screw the screws back in with a screwdriver.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2指南评论
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - 回复 分享
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 21
过去 30 天: 116
总计 3,877
