简介
If your speakers keep cutting out or are no longer working at all, you will follow this guide to replace them. Beyond just being screwed down the speakers are also glued into place and must be torn/pulled off in order to access. Soldering is also required to remove from motherboard, so use caution.
你所需要的
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
在这个步骤中使用的工具:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
在这个步骤中使用的工具:Tweezers$4.99
Using the Ph1 screwdriver, unscrew both of the 2.5mm screws on either side of the speakers.
Solder your replacement speakers back to mother board, then to reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
